DIY Welding Project: Expansion Tank | MillerWelds
DIY Welding Project: Expansion Tank [Guide]
Share
When you have a leaky or worn-out seal under the hood, follow these instructions to make an expansion recovery tank.
SKILL LEVEL: Intermediate
TIME COMMITMENT: 2 hours
Here's what you'll need to get started.
TOOLS AND MATERIALS
Miller® Multimatic® 220 AC/DC multiprocess welder
Brass filter
6063 or 6061 alloy aluminum round tubing (1-5/8" x 1/8") (5" long)
1-1/2" x 4" x 1/8" aluminum plate or flat stock for the mounting bracket
1/4" aluminum plate or flat stock for the end caps
Hole saw
Sander/grinder
Hand drill
Drill bits (5/16", 7/16", 33/64", 9/16" x 18" fine tap and 1/4" pipe tap)
Vise
3/32" 4043 or 4943 filler metal
5/16" rivet nuts (2)
Rivet nut setter
1/2" wrench
WARNING: READ AND FOLLOW ALL LABELS AND THE OWNER'S MANUAL.
STEP BY STEP
Round tubing being cut.
STEP ONE:
Take your round tubing and cut to desired length; remember to deburr the edges. Mine was cut to 5" long.
Operator using hole saw to cut out end caps.
STEP TWO:
Using your 1-3/4" hole saw, cut two end caps out of the 1/4" aluminum. Sand or grind the rough edges if needed.
Operator tapping the end cap for the brass air filter.
STEP THREE:
Using a hand drill and vise, drill 7/16" hole and thread with 1/4 NPT tap for the brass air filter. I used a 33/64" bit and 9/16" x 18" fine tap for the bottom fitting.
Welder TIG welding the end cap to the round tubing.
STEP FOUR:
Set the Multimatic 220 AC/DC to 200 amps, 73% balance and frequency set to 90 hertz; then TIG weld the end cap to the round tubing.
Welder welding to the round tubing.
STEP FIVE:
Take your mounting bracket and drill two 5/16" holes 1/2" from each end and 3/8" from the edge. Weld to the round tubing.
Operator attaching the expansion tank to the plastic case.
STEP SIX:
Attach expansion tank to vehicle by drilling two 7/16" holes into an area with backside clearance, and use 5/16" rivet nuts with 5/16" x 1" bolts and lock washers.
Operator attaching the vent hose to the expansion tank using a wrench.
STEP SEVEN:
Finish by attaching the vent hose to the new expansion tank.
About Andy Weyenberg
Andy Weyenberg headshot
Andy Weyenberg began welding at his father’s business a few years before joining the Army. After going to school for Electro-Mechanical, he started working for Miller Electric Mfg. LLC as a technical service rep and training instructor. Andy has built and raced stock cars since he was a teenager — and now builds high-performance street vehicles while also managing the Miller motorsports program.
Published:
